I am after two final parts for the XM which are proofing tricky to source through the usual channels, first off a radiator shroud from a 2.1 td, I don't have a picture to hand but anyone who has one will know what I mean.
The second item is a little harder to track down, a early sinker pump belt cover as seen below
[youtube]fvlL-r8nm6I[/youtube]
Any help in sourcing these two will be much appreciated before I break out Google trans and start trawling euro land.
All i want for xmas
All i want for xmas
Re: All i want for xmas
Did we actually have those covers here in the uk... ive never ever seen one in the uk...
Actually dean I dont know what you mean by the rad shroud!??
I have never seen a pump belt shroud... Huh!
Do you mean the plastic cover that hides a coolant pipe on top of the rads. Sits right behind the main GRP front end where the stickers go?
Might be able to get you one. Shall check my sources!
My source has one. It's yours if you want it Dean....
Paul, i am starting to think they were a euro issue only item which is just plain odd, the search continues! French ebay has some vast lists of XM bits but as yet i cant find what im after.
Russ, it is that bit and if i could have it that would be great, thank you, let me know how much and i will push some pound coins down the phone line for you.
Thanks Russ, just let me know when your ready.
This pump cover is really going to be tough to track down, can't think why it only seems to be fitted to early French farmer spec 2.0 petrol cars though.......
cxprestigeauto
Aghhm "early French farmer spec 2.0 petrol cars though."
As the proud owner of an early 2.0 petrol I take exception to this. The first owner was an English farmer
, really it was an English farmer........!!!!!
Yours isn't FF spec, you have chunky 195 tyres, a centre console, tacho, glove box lock, spoiler, auto transmission and so the list goes on, your is pretty much a palace on wheels!
Click below to enjoy real poverty spec XM motoring at its best!
viewtopic.php?f=6&t=1097&p=11058&hilit= ... pec#p11058" onclick="window.open(this.href);return false;
