front struts and tops, ecus
messerschmitt owner
Post by messerschmitt owner »
complete pair of front struts from S2 estate 1996 R Reg - everything from brake discs and abs sensors to strut tops and rechargeable spheres - good tops. No ABS faults when car last started two weeks ago.
£125 for both - includes free near side driveshaft from XM 2.1TD manual.
suspension ECU with e-crofting kit fitted £30
abs ecu and pump £25
e-crofting window regulator cables brand new £12 a pair.
I'm in Gloucestershire but between now and the New year will be in Wickham, Hants, Kempton Park and central London so could bring closer to you.
Image[/url]
messerschmitt owner
Re: front struts and tops, ecus
suspension ECU off to a good home -
new prices
£90 the struts/tops and abs sensors, with everything else in between
abs ecu and pump £15
new things
front sidelights - two pairs, mixed condition but one decent set between the four lights £25
tail lights for XM estate £15 the pair.
double radiator set up from XM 2.1TD non-aircon £30
e-crofting cables and instructions £12 for a pair
Image[/url]
jonathan_dyane
Post by jonathan_dyane »
Off what year of car? I think there are two types; the series 1 variant with 'proper' hoseclips and the series 2 type which had bayonet hose fittings and was shared with the 406.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
It will be a Series 2 type, as that is what Messerschmidt's car was.
messerschmitt owner
it was an S2 set up and it's away! Spirited off to Cheltenham...
Image[/url]
:oops: Yeah they are in the garage...I was instructed to take them away! :lol:
