Further XM Items.. Keep checking back . First update
Post by citroenxm » Sun Nov 08, 2015 12:32 pm
Further my other post, here are more items which will be availble for you lot to make offers on. These are items that there are more then 2 of, so wont affect what I have here. Im not leaving myself short. Rare stuff of mine you wont see... This will take time to list up, but do keep a check.
OFFERS on anything. Thanks
PRV V6 Distributer covers, top and bottom halfs..
S1 Interior Fuse Boxs
Idle Control Valve units
Parking Brake Equalizer unit under car next to exhaust
Ash Trays, fronts and rears..
Roatry controls for heaters, the ends where the metal spring sits break a lot..
LOADS of Grab handles in grey and black, but I guess these dont break to they!
Interior door open handle surrounds trims, absolutly loads of them too!!
Early early Roatry main lights on switch's that fit in the steering cowling.
LH Displays, again a non failing item on S1 cars hence having loads of them. Id have to try and make a conversion harness to make them work in S2 cars, though they arent hard to fix now either... but, they are here anyway...
Horns! Loads again
Door Puddle lamps, loads again
Petrol intank fuel pumps, about 5 of them
Roof console that has the IR plipper reciver and cabin Temp sensor.. These can break where the cortesy lamps sit, and they come away.. We have them in Grey and black
Bonnet Catch mechanisems.. non siezed
Coolant expansion bottles, not certain if these suffer splitting or not. Mine never have.
Loads of wiper arms, if your springs are weak...
Seem to have what I think is 5 nearside front window winders, electric... so possibly 2 for sale
Battery clamps, but no bolts to attach them, though no doubt sourceable..
Couple of LHM HP Pumps, 2.1/TCT and V6 sort
2.1 TD engine.. needs one hydraulic lifter, but had a head gasket not that long ago.. Brilliant runner.
Windscreen washer and rear screen washer motors, bottles available, but I dont think they leak often, but motors fail.
Battery Clamp... minus the long bolts, but im sure they can be sourced. possibly two spare.
To be continued....
Sam Skelton
Re: Further XM Items.. Keep checking back for additions
Post by Sam Skelton » Mon Nov 09, 2015 11:49 am
How much for the LHM pump, TCT spec? What's its history - the car it came off etc?
Sam Skelton
Frenchies on my fleet
88F Citroën CX Croisette (RP4138)
93L Citroën XM 2.1SD auto (RP6043)
93L Citroën XM 2.0ct SEi auto (RP6045)
94L Citroën XM 2.1D auto (RP6251)
99V Citroën Xantia HDi110 Exclusive (RP8358)
cxprestigeauto
Post by cxprestigeauto » Mon Nov 09, 2015 3:21 pm
Paul, can you add a rear ashtray to my parcel? If you have already posted it out then no worries.
Extra £3 cover it?
Post by citroenxm » Mon Nov 09, 2015 7:17 pm
Not been back to the farm yet!!! So no worries.. ill try remember..
Post by citroenxm » Mon Nov 09, 2015 7:20 pm
Sam Skelton wrote:How much for the LHM pump, TCT spec? What's its history - the car it came off etc?
Its a used pump Sam.. it works.. but thats all I can say..
offers sam.. plus post.
cheerz
Eddie nuff
Post by Eddie nuff » Mon Nov 09, 2015 9:55 pm
citroenxm wrote:Early early Roatry main lights on switch's that fit in the steering cowling.
Put my name on them Paul.
Re: Further XM Items.. Keep checking back . First update
Post by citroenxm » Sat Nov 14, 2015 7:17 pm
Original post has had an addition...
Keith10
Orga / RP numbers: XM 2.1 TD auto hatchback RP is 6045
Post by Keith10 » Thu Jul 14, 2016 1:23 am
Hi
Do you have the following for Y3 1993 XM 2.1TD:
1) RHD drivers side complete wing mirror
2) Towing ring front cover for front bumber
3) The curved short cover that sits immediately in front of the wing mirror drivers side and immediately behind the bonnet
4) The front RHD drivers side abs front wheel speed sensor (green plug) may be interested in all 4 front and rear.
Thanks Regards
Keith
cxprestigeauto
Post by cxprestigeauto » Thu Jul 14, 2016 10:12 pm
Keith,
I have an early Y3 (1990) grey RH wing mirror that you can have. The mirror fixing has failed but all the housing etc is good.
Towing eye cover (rare as hens teeth unless you are in a French scrappy and even then........)
Scuttle end trim not quite as rare but usually with broken clips.......
Early ABS sensors if they turn up unused very expensive and impossible to extract without the aid of a drill once in place for 20 plus years!!!
PS Paul, if you are reading this where is my paint and rear ashtray???!!!!
Post by citroenxm » Fri Jul 15, 2016 9:06 am
Hi rob.. Well i was expecting to see you atca rally..
Anyway.. I guess that wont be this year.. Ill get it together and off to you.. Which paint was it again?
