It's alive......IT'S ALIVE!!!
Ciaran
Site Admin
Orga / RP numbers: 1234
5678
91011
Post by Ciaran »
Hi guys,
The forum is back online after 6 days downtime.
Sorry for the extended outage, unfortunately what started out as a simple issue grew into a series of problems.
The original database server died last Monday morning. I was expecting this, and had a new server built, ready to replace it.
Unfortunately, when I went to restore the backed up database to the new server, I discovered that there was some internal corruption within many of the data tables, this prevented the database from mounting on the new SQL server.
This corruption has gone back for some time it appears, and as a result all the recent backups had it.
Because of this, there was no option but to manually create new versions of the corrupt tables from scratch and then import the data from the corrupted tables to them. There are well over 100 tables in the database and many of them contain upwards of 100 columns each, so manually mapping and checking the datatypes etc took literally days. This is the reason for the site being down so long.
The upside of this, in a lessons learned kind of way, I've altered the backup scripts to include database consistency checks, so it will check the integrity of the data in the tables rather than blindly backing it up and assuming all is well. You know what they say about 'assume', it makes an ass out of u and me :lol: .
So after all that, the database finally coughed and spluttered into life like a 2.1 on a sub-zero morning, that sound we all know and love :lol:
We're back up and running, sorry it took quite so long!
Ciarán
Re: It's alive......IT'S ALIVE!!!
Thank you Ciarán for all your hard work, it is very much appreciated!!
eifion
Post by eifion »
Blimey, that sounds like a lot of work. Congratulations on getting it all back up and running.
1995 XM 2.5TD (now dead and gone)
1998 XM 2.1TD Auto Estate
2000 XM 3.0V6
1972 D Special
Post by Peter.N. »
Thanks Ciaran. Thought it was my computer ;)
Julianw
Orga / RP numbers: 4937
Post by Julianw »
From bitter experience, I know how much work you had to do there. Thanks for all of it!
Sent from my GT-S5830i using Tapatalk 2
cxprestigeauto
Post by cxprestigeauto »
Cheers, Sounds like working on the XM is the easy option!
Many thanks for all your hard work.
raynoon
Orga / RP numbers: 6043
Post by raynoon »
Welcome back! And thanks for all the hard work you put in to keep us going! I've had withdrawal symptoms all week!!
Post by White Exec »
Ciaran, thanks for all that hard work in getting things going again. Good to be back up.
dollywobbler
Post by dollywobbler »
Good work! Gosh I've been missing this place. Your efforts are very much appreciated.
1986 2CV6 Dolly, 1980 Dyane
Post by captainhaddock »
Hope I wouldn't give up on a XM as I surely would have with such a computer problem ;) Cheers! I'll get ready to throw up some XM related issues...
