Front Indicator connector block
raynoon
Orga / RP numbers: 6043
Post by raynoon »
I'm after a connector for a front indicator, need it with a few inches of wire too, for a series 1.5' anybody?
Re: Front Indicator connector block
Ooooo.. Urrrmm... Thats the one with main headlights on switch and full beam..
Having said that.. I think the harness are all mixed up now..
Ciaran
Site Admin
Orga / RP numbers: 1234
5678
91011
Post by Ciaran »
Hmmm, what's happened your existing block Ray, has someone butchered it previously?
I'll be breaking an S1.5 over the coming month or so, so should be able to hoke out the connector if you're still stuck.
Ciarán
raynoon
Post by raynoon »
It's ok, I've re-wired the existing unit. The wires were brittle and when I removed the fog light/indicator light the twin earth snapped.
I could do with another one if there is one going. Let me know if you're breaking this 1.5 as I think there are a few other bits I would like.
Many Thanks!!
