Finally arrived back in Kent late last night.
600 miles from Ireland via Cairnryan.
She didn't seem unduly stressed... And nor did her driver... Will post some photos later.
Rory
Hi Rory,
Have you set the picture as your signature as it is appearing on every post you make. As a signature picture it is way too large.
Open up your picture in Paint, Picassa, or something like, and reduce to 10% of size (or even less) to make it a thumbnail, to replace the original.
BTW, is that a view of the car from a nice old tram or railway carriage?
Chris 1996 XM 2.5TD Exclusive RP7165 Polar White 1992 BX19D Millesime RP5800 Sable 1989 BX19RD Delage Red Deceased; 1998 ZX 1.9D Avantage auto Triton Green Company car 1998..2001; 2001 Xantia 1.8i auto Wicked Red Company car 2001..2003
...yes, and the blacked-out chrome trim. Very North American Amish!
Well 6 weeks into ownership and still enjoying every moment...
Slight problem with the rear cigarette lighter but, touch wood, other than that everything is good..
I think I am even getting used to the footbrake...
Rory
The footbrake is a bit fiddly until you get the hang of it on a manual car, simple enough on an auto.
Just think how fiddly it would be in original domestic market LHD form, stopping on a hill would be interesting, at least they got a foot rest though.
Always thought the pedal should be damped to stop the clunk on release that's hard to avoid on manual cars when setting off.
You know, it's rather strange. I was afraid of it a bit, too, after the BX and AX. But I hardly ever use the foot brake for anything but parking. LHD. Even on a hill, the normal brakes and quick handling of the clutch/gas seems to do it every time. You simply grab her before she starts to roll in the wrong direction.
Sent from my HUAWEI P7-L10 using Tapatalk
Bye,
Gábor
I never use the footbrake for hill starts, but don't find it a problem anyway. I understand the concerns about the ratchet wearing out, but in reality, it's not going to happen, so keep the release pushed in, other than when releasing the pedal.
The same system is fitted to most Mercedes and the release is spring loaded to always be int he latching position. I've never heard of one wearing out.
