Scuttle trim and end caps
Onion Johnny
- Orga / RP numbers: RP7302 Silver 01/1997 Series 2 Hatchback. 2.0 TCT
Any body got the windscreen scuttle panel and end caps in good condition to fit a Ser2 ? Navy Blue would be perfect but can paint if need be.
Fiatson
Fiatson
Re: Scuttle trim and end caps
Hi there, and welcome.
If you haven't actually lost the two end pieces, but the fixing tabs are just broken, it is possible to reattach them simply by using a couple of well-placed dobs of silicone sealant. Can be pulled away later, if need be.
southerner
I have a 1.6 one, from the XM that I have broken up into part's. Don't know if it will fit a mk 2
Panel fits but Mk1 end caps do not fit Mk2's.
There must be loads of Series 2 end caps available.
If nothing else comes along, you could try haggling for these: http://www.ebay.fr/itm/JEU-DE-2-JONCTIO ... 5d5a45823a" onclick="window.open(this.href);return false;
- onza100
I'm breaking a s2 at the moment. I can try and get them off without breaking them for you if required.
Onion Johnny
Yes please and the painted scuttle panel too. I think the screen was changed and the fitter's monkey got the job! Haynes manual tells you how to get them off. Might be helpful to warm up with a hair drier to lessen the britleness.
Ian
Ian
I find lifting the upper section over first works without snapping the lower fingers.
- onza100
I've just gently taken these off using Dieselmans suggested method only to find the lower fingers are missing already. You couldn't tell with them on the car.
The scuttle is in good condition.
