Wanted NSF door glass edge strip
I need the door edge to glass weatherstrip for the outside of a NSF door. I foolishly removed mine to paint the door and the inner section split away.
jeastham
Re: Wanted NSF door glass edge strip
Post by jeastham »
Dieselman wrote:I need the door edge to glass weatherstrip for the outside of a NSF door. I foolishly removed mine to paint the door and the inner section split away.
I believe I could help you out, here.
Justin
1993 2.1SED Auto. RP # 6084
Can you get it off without it splitting?
There is a retaining nut at the rear edge, inside the door then it would be best to press it up from below, with the glass removed.
jeastham
Post by jeastham »
Dieselman wrote:Can you get it off without it splitting?
Not keen on removing the glass just yet; but the motor is removed; so I'm guessing I can drop the glass right down
The glass will need to go below the normal lowest height, so will need to be unclipped. From there removal is a 30 second job, just tilt it and pull it up out of the door.
southerner
Post by southerner »
You know where I am if you get stuck.
Have you got one in good nick?
Post by MTXM »
I also have several of these already off cars Will and I will be at the National if you can wait until then. With regards, Matthew T.
southerner
bit og green stuff on them but the look fine
