Finally found an XM here in New Zealand to buy, 400km away from me. Hopped on a bus, bought it and drove the 400km back home.
Anyway about the car, it's a 1992 V6 12v auto, 110000km (68000 miles). Two owners from new, the second owner only had it for 2 years and never really drove it, first owner took very good care of it, always dealer serviced.
There are quite few issues to sort out on it, but nothing too major. Here goes...
-Speedo cable snapped at speedo head, both plastic clip and inner cable have broken
-Interior fan / heater controls not working, also broken recirculation flap bits on panel.
-fog lights not working
-passenger seat not moving forward (shaft from motor has snapped in two)
-suspension totally solid, believe it is just spheres.
-glovebox done the usual failed strut and broken latch (grey plastic too not normal black)
-interior lights not working
-trip computer not reading distance or fuel usage
I think that is all, sounds like a lot to sort out but should have it done rather quickly (hopefully
I have already got the dash out to remove the speedo cable and fix the heater panel , hoping to find a NOS one somewhere, get it remade or possibly second hand. Also removing the dash revealed wiring for interior lights messed around with and what I believe is the fog light relay had also been modified (extended from the fusebox and second relay added? I will have to post some photos of it)
Will hopefully be updating this regularly with everything I do to this car, I never did with my other XM but would like to start. Will post some more photos when I next get a chance.
Jordan.
IMG_0441 by JD01JD, on Flickr
