I know that this is a LONG shot but..........
Having gotten round to the N/S sill hole this evening I have discovered that Bodgit & Scarper got there first!
The gap between wing/sill and splash guard was VERY full of assorted mud and debris.
The wing bottom which looked OK has been filled and is generally worse for wear. The rest of the wing is good.
Whilst I can fold up a new lower wing section a replacement panel would be easier so....
Does anyone have the bottom 20 cm of N/S wing in good condition? I don't need any more as I will just graft it in along a fold line.
I know they all rot out at the base but just in case someone has a damaged panel.......
I assume the S1 and S2 are the same at the base of the wing?
You can only ask...........N/S wing part panel wanted
cxprestigeauto
Re: You can only ask...........N/S wing part panel wanted
Hi Rob,
Cut and join behind the black trim that runs along the wing. It should make the repair invisible. Or just stick a whole wing on.
Near side and white Rob??
I MIGHT have a whole wing but would need to check it out of course!!
cxprestigeauto
Thanks guys. Any help appreciated!
Paul, enjoy the rummage!
PS keep an eye out for the exhaust system while you are in there.
Dont worry about that.. I do know where that is this time!!!
