Greetings
Re: Greetings
Dan, there are always questions!!!!
A few minutes spent checking the previous postings is often time well spent but I am always happy to ask the numpty questions to my elders
and betters (?)!!!
Re: Greetings
ha, me too Rob.....I will say hi back Dan. Guru or not, even I stumbled into an XM question today
Re: Greetings
Welcome Dan and we look forward to your further posts!! Regards, Matthew T.
Re: Greetings
Thank you all!
Having found an extra Owners Manual in the fuse box, discovered that I must drive with the emergency brake lever 1 up and put the CDs in correctly, I feel things are going well.
Next to sort is the snking after leaving for 1/2h and other things including a mystery button.
1995 XM 2.0T CT Exclusive, Burgundy
Alpina B10 V8
Alpina B10 V8
Re: Greetings
How old is your car? Older XM's didn't have 'anti sink' so it's normal they sink to the ground after a while
Re: Greetings
1995.
I tested if it went up and down after ignition off, which it did. A sign of the later anti-sink I believe according to this forum
Alpina B10 V8
Alpina B10 V8
- fakeconcern
Re: Greetings
Hello Dan
I am new to XMs as well & have already asked plenty of stupid questions without being ridiculed (that much!)
1995 XM V6 Exclusive
2005 C4 VTS 180
2005 C4 VTS 180
Re: Greetings
Well fakeconcern, you've been pretty active for a new member!
Alpina B10 V8
Alpina B10 V8
Re: Greetings
No, it is the other way around. An anti-sink car will not lower with the height control unless the engine is running.VCat wrote:1995.
It should be easy enough to count the pipes on the hydraulic pump, a sinking car has one inlet and one outlet, a non-sinking car has one inlet and 2 outlets.
