Could some kind soul tell me the part number for a genuine inboard drive shaft gaitor to fit a MK2 TCT Auto estate reg N510 LCD
Thanks
Part number Required
Re: Part number Required
Inner
Référence Désignation Quantité Prix HT Prix TTC Total TTC Sélection
0000328790 ENSEMBLE PROTECT TRANSMISSION 18,25 GBP 21,90 GBP 21,90 GBP
(REPERE 9617054480)
0000328780 ENSEMBLE PROTECT TRANSMISSION 26,30 GBP 31,56 GBP 31,56 GBP
(REPERE SOUFFLET 9620994180)
Outer (wheel side)
0000329302 ENSEMBLE PROTECT TRANSMISSION 26,32 GBP 31,58 GBP 31,58 GBP
(REPERE SOUFFLET 1476526080)
00003293A1 ENSEMBLE PROTECT TRANSMISSION 17,26 GBP 20,71 GBP 20,71 GBP
COTE ROUES (REPERE SOUFFLET 9621157680)
(REPERE 9617054480)
Outer (wheel side)
Thank you Robert, not the answer i wanted but thank you non the less
Nothing is ever easy with these cars! I'd go for the cheaper of the 2
Does anyone know the difference between the two parts? i know auto and manual have different shafts and no supplier seems to state there is a difference, ive found a gen part which is what i want and its a good price but want to be sure of what the difference in the two parts are.
Thanks
Thanks
The main difference as far as gaitors are concerned is the diameter of the outer shaft.
Around the beginning of 1996 Citroen changed from solid to hollow outer shafts.
Hollow and solid shafts for a particular Mk2 engine/box type are interchangable.
The problems start if you need just gaitors or joints.
For those parts the shaft diameters need to be measured and specified.
Most Citroen gaitor boxes I have specify the diameters so the seller should be able to check for you.
