Breaking XM 2.1td manual
messerschmitt owner
everything must go, it will be a shame for useful parts stay on the car and end in a breakers.
Have the kit to remove the engine but not the time ... if you want it, come and use the trolley jack and engine hoist to take it out ..
All parts cheap. Want to keep it mobile as long as possible so, no vital electrical, engine parts until the end ...
Good engine and box,good struts
leather interior
working remote key fob
good panels in dark blue
reasonably good struts
Large parts collect only ...
If you're quick, make me an offer for the whole thing
sunroof cassette already available as I have one that worked when it was removed from another car already in the garage.£40 provisionally SOLD
almost new (Witter, I think) estate Towbar with factory Citroen Accessorie wiring kit - no towball. £50
pair of sidelights £30
leather interior
Last edited by messerschmitt owner on Mon Jan 12, 2015 2:57 pm, edited 1 time in total.
messerschmitt owner
Re: Breaking XM 2.1td manual
interior sold
sidelights sold
adding to list,
All these post free
purflux fuel filter housing basically everything that bolts to the battery box- good condition, no leaks - been fitted and tested to Russ's old car £25
hydraulic pump from S1.5 2.1TD £20
indicator switch £15
windscreen wiper switch with variable intermittent wipe £10
three S1 original style hubcaps in acceptable condition £18
ideally the below for collection only
sunroof wind deflector in blue pastic - will fit BX or XM £30
set of four steel wheels in excellent condition - no tyres - £15 for the four -
sidelights sold
adding to list,
All these post free
Last edited by messerschmitt owner on Sun Jan 11, 2015 5:43 pm, edited 1 time in total.
What are the sizes of the CV boots? Is it for the larger, tubular shafts and smaller inner joints and are they oe?
I need a set and was going to eBay them last night but if yours fit.
messerschmitt owner
they are Motoquip VCV329 so OE
which I've just cross-referenced and they're not XM
Renault
They came out of the back of an XM I scrapped and I assumed they were just XM ones= silly me!
Renault
Right, I must get this engine hoist and chains back to you as soon as poss. When are you free Campbell? Would it be possible to do it in daylight?
messerschmitt owner
apart from Wednesday I am about all week.
I thought Savoy was interesting in the car complete?
station
Hi Campbell,
I'm after the lockset (ignition/doors/boot/glove box/under bonnet alarm) if it's working/OK? Not sure if the alarm/CL thing works off the black box under the glovebox (plugs in with two plugs). I disconnected mine as I couldn't turn the alarm off.
Thanks!
Thanks!
messerschmitt owner
Dave
the alarm - you have to switch the ignition on and press the alarm buton on the dash until the alrms go off - it'll be the red one that is on on the left hand side of the buttons on the centre of the dash.
I can sort out the lock set for you but it won't be immediately, if that's OK - what I can do initially is pop the door barrels out and send you a key and them up - is that OK - ignition switch won't come out until close to the end as I don't want to make it immobile.
I'll save you the remote key (as it works) and control box for it too.
Campbell
Campbell
station
Yes, that's OK, thank you very much, I can't lock the doors at the moment unfortunately ha!
[/url]
