Hello all,
I am sure there will be more needs to come so here is a starter for 10.
Handbook for 1991 car (I have loads of paperwork for the car down to the PDI and letter from the garage to the original owner but the actual handbook is missing)
O/S rear window mechanism/glass with guide pin or just the guide pin? Not sure what has happened but the window won't go up all the way and there is a hole in the front of the glass that would seem to require a pin? Any advice also welcome.
Front door lock buttons and clips to hold them to the stems (Both missing sides missing)
Both ashtray/power point covers from the centre console in the back of the car. The rear seats look like they have never been sat in but someone has kicked both covers to death.
N/S tow hook/tie down cover off the front valance.
A lock set, the car has three keys and so far I have only found what two of the keys are for! This seems to comprise: two front door locks, one ignition barrel, one boot lock and one lock on the glovebox (this is the least of my worries!)
Many thanks for reading this. Please send me a PM if you can help and I will send you my mobile number. Happy to pay sensible prices for good parts and associated P&P.
List 1: Stuff for Rob's new car
cxprestigeauto
cxprestigeauto
Re: List 1: Stuff for Rob's new car
Thanks to XMexclusive I have now sorted the door lock buttons and window glass.
Hopefully the brochure as well but John is checking stock!
Any other bits please give me a PM and cash awaits.
Hi Rob,
ok.. Handbook. I THINK I can find one should be able to, as long as I got one for my V6 24v XM then Ill be happy.
Rear window glass has a Guide Plastic with two proud points, that sit in the window, and is pushed into the glass seal, which is what guides the glass.. Should be able to find one of those, I wonder if they are the same as the Xantia ones, theres 4 on a Xantia I want to get rid of.. Ill check the Pt. numbers on service citroen..
Bumper Tow Eye covers are rare things, most do go missing. Dont think I can help with them.
Ill check what centre consoles I have and see if theres any rear covers present. Be aware, that centre Ashtray/Power point section DOES pull out of the centre console as a full alone piece...
