LHM tank pipe and filter housing
Aerodynamica
Post by Aerodynamica » Sat Dec 20, 2014 6:26 pm
Hi all, further to the post in the hydraulic section, I need to replace the LHM tank central plastic core that fits all the rubber hoses and houses the LHM filters. Mine has a crack in it that's drawing air at the HP pump suction pipe.
Not fussed if it's the correct black XM type or the white BX type (might actually be better and less brittle than the black?)
Any help greatly appreciated - it's my daily car!
Re: LHM tank pipe and filter housing
Post by Dieselman » Sat Dec 20, 2014 9:07 pm
Are you sure it has a crack?
Aerodynamica
Post by Aerodynamica » Sat Dec 20, 2014 9:56 pm
Yes, it's visible if you apply a little pressure to the surface but otherwise it is near impossible to see as the crack fits together perfectly. It it there though and if you press it a bit with the engine running the pipe fills up with bubbles until you release it - it is definately drawing air through the crack. Might not be common or ever heard of before but it has occurred here!
Anyway, if no one can help with this part I'll be forced to either borrow the one from the CX or fit a pipe extension down into the LHM tank to keep it healthy until I can replace it.
Post by xmexclusive » Sun Dec 21, 2014 12:01 am
Ebay item 191199729302 & 260683469440.
There was a new XM tank centre listed until recently.
If I find a link I will add it.
Aerodynamica
Post by Aerodynamica » Sun Dec 21, 2014 12:29 am
Thanks John
Post by Dieselman » Sun Dec 21, 2014 7:47 pm
I'll have a look. I should have one.
Aerodynamica
Post by Aerodynamica » Sun Dec 21, 2014 10:05 pm
That'd be great if you can find one
Post by citroenxm » Wed Dec 24, 2014 10:10 pm
And how many XM have I broke, and kept every tank!!!
All over the place. If all other offers above fail, SHOUT!!!!!
Aerodynamica
Post by Aerodynamica » Wed Dec 24, 2014 10:58 pm
Haha brilliant, think I might need one of yours after all.
Post by xmexclusive » Sun Jan 04, 2015 10:23 am
NOS tank centre now back on ebay.
Item 231435195037.
£55 inc postage.
