Its a long shot but does anyone have a good abs wiring harness?
Mine has been hacked and chopped about so I'd like to start with a decent one.
Thanks
Bendix abs wiring harness part no. 6526J2
- onza100
Re: Bendix abs wiring harness part no. 6526J2
If you can find another harness, and it isn't too daunting to fit it, then ok. If the damage to the wiring is only that one local spot (as per the photo), then there's nothing wrong with a tidy bit of end-to-end soldering, with some heat-shrink sleeving over each individual joint.
- onza100
One whole sensor section has been badly replaced on mine.
Whilst I could remove, continuity test it and fix all the broken wires it would be nice to have a spare ready to refit save making the car immobile to long.
Fingers crossed some kind soul will have one
