XM 2.1 TD Estate K reg
diawl
- XM newbie
HI
Looking for good usable main oil feed pipes for the rear suspension struts,10mm diam any help with suppliers or you have a spare set let me know.
thanks
thanks
Re: XM 2.1 TD Estate K reg
Hi diawl
Have been looking for these for quite a while.
Not found any used ones good enough to recover.
Always very heavily corroded.
Looks like it will be Citroen or get them made up.
Are they the same as hatch ones?? I also do know that later pipes from cars with anti sink are also different to early ones without anti sink..
ive got a fair few hanging up in my shed off mark one hatch models...
Same pipes for hatch and estate.
I thought they were, Thanks Edward ...
If there are no pipes available, a series 1- 2.1TD would make an interesting proposition.
Ive shit loads of rear pipes hanging up in the shed, ill check their overall conditions...
kingp
Even if you got some rotten leaking pipes they could help make up new ones as all you need is the unions off them for a hydraulic specialist to then remake the rest of the pipe, although I believe someone has 100's of unions in their stash...
Whos that then Will with loads of unions? , Ive loads of NON Leaking pipes complete though...
kingp
I've been told not to say
though I'll say they cleared out all the stock GSF had! In the country!!
