Here is a link for anyone interested:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1285259350
With regards, Matthew T.
Leather interior on ebay!
Rommel
Re: Leather interior on ebay!
How do you tell if they are S1 or S2? Decent price indeed.
Rohan
ES9 V6
Previous:
2.1TD Exclusive Orga 6668
2.5TD VSX Estate
ES9 V6
Previous:
2.5TD VSX Estate
Series 1 late high spec car so chances are they will be heated.
They have mechanical spring seat belt tensioners which is the key feature visible to decide type.
Early and low spec Mk1's had untensioned seat belts.
Mk2's all had explosive seat belt tensioners.
- onza100
Would they be a pain to put in a s2 vsx?
Probably not! I have a set of wood effect door cards that would go nicely with these seats to finish any interior off..
Vsx already has electric seats so it should be a straight swap an plug in for power to the seats.
Swopping the bases over isn't that big a chore. If you are going to swop the interior over, you will be able to swop the bases over. There are large torx headed bolts holding the base to the seat frame. You'll need 12V battery and cable on hand to make the runners go back and forward to clear the bolt heads.
- Vieil Homme
- Orga / RP numbers: 7522
I also have a complete black leather interior (from a -92 Berline)
Incl. consol and panels for all 4 doors. Electrics and ass-heater works.
No damage at all to seems and leather in perfect shape.
Trouble is.............freight Sweden - UK............
kingp
Never any from an estate though and penrith isnt too far from me really
Its only the car rear seat back that does not fit an estate.
Weld brackets to move the seat back top corner fixings in 30mm or so and the car seat back will fit.
Make sure you get the car rear seat side squabs then all will be fine.
Evey other part of the car and estate body is dimensionally identical.
Note that car leather rear seats are all one piece.
Estate rear leather always came as split seats which is why it is so sought after.
kingp
Hence why I want them
it makes life easier with certain loads and helps keep a bit more noise out at speed that hounding get when the whole back is down
