Speedo cable
- XM newbie
Speedo cable
Hi, has anyone got a complete speedo cable (either one piece or two piece?).
Re: Speedo cable
The lower piece that connects to the transmission is still available from Citroen. I've just had it done.
Citroen XM (MK1.5) Prestige, 2.0i Turbo. Black
Re: Speedo cable
It will be necessary to know which type Mary as early models have different fittings due to the location of the speed sensor. Regards, Matthew T.
Re: Speedo cable
There used to be a firm in London called 'Speedy cables' that would make them up, it was about 50 years ago but I believe they are still going.
Re: Speedo cable
Speedy Cables still there, so far as I know.
Re: Speedo cable
Re: Speedo cable
Not really Mathew! The two types of speed sensors are changable. My H reg S1 24v has the speed sensor ON the gearbox, with a cable extension down to it, yet the H reg 2.1 SED has it in the split at the top by the bulk head.MTXM wrote:It will be necessary to know which type Mary as early models have different fittings due to the location of the speed sensor. Regards, Matthew T.
However, your point about cable types is vailid, as I beleve the connection are different..
Re: Speedo cable
My problem is that I need the drive for my CX. The gearbox type will not fit the CX but the type that fits in the cable join will.
Citroens: XM V6 24v ES9, CX GTi Turbo 2 Familiale "The Flying Cigar", AX TGE1.1
Previous Citroens: C6 V6 Exclusive Petrol, XM V6 SEi Man, XM V6 Exclusive Auto ZPJ, BX14, 2CV Dolly, Visa "Van Rouge", CX 25 RI Familiale
Re: Speedo cable
Right.. as said. I had some or one with me at cosford xm rally..
Re: Speedo cable
I can recommend speedy cables...made a cable for my cx as well. Cheap and well made.
