Hi all
I am after a few bits i've misplaced or cannot otherwise source, if you have them to spare could you PM me with what you want for them including postage and i will send funds via PPal, the list may grow over the next few weeks but to start off i need.........
Washer bottle filler neck with cap and rubber seal
Washer bottle rubber mounting gromet
lhm return pipe from Bendix Valve block.............could make one but just on thd off chance
OE loom plugs for wing mounted repeater indicators with a couple of inches of wire still attached
a pair of lower front wing securing clips that locate over the outer cill plate in the cill vent hole (cant remember what they look like)
Jacking point covers, (ive got two could make others)
Thanks
Parts required please
Re: Parts required please
Should be able to sort that out for you dean EXCEPT the jacking point covers...
I will look for jacking point covers as I delve into the pile.
For the pipe get it made up with the large head nuts rather than the small thin Citroen ones.
I will do this if you give me size and length.
Hi dean.
I have rounded up washer bottle filler with lid but not attached anymore.. a filler to bottle seal rubber.. a mounting rubber ring to go on one end.. and both indicator wires to the front wings.
whats the pipe you want .. rubber or metal pipe?
Thank you both!
Paul its the rubber return hose that comes off the top of the ABS block then gathers in with the return line from the pressure regulator and then up to the lhm tank.
If nobody has any lower wing securing clips its no problem but it would be nice to have a picture of one and i can fabricate it...................
John, go carefull in there!
Ahh its typical citroen and is part of a complete return manifold maze... not a single pipe in its own right.
id not want to cut one up really dean. It goes to the back of the engine bay where it meats the PAS rack return pipe and goes up to the tank. I think the flow divider and pressure regulator leak returns also meet it and are part of it.
im sure the lower wing clip are simply a U clip squeezed together because the area the wing meets is raised to meet the bottom... and the clip is simlly pushed on to hold them.
No wr=orries Paul, that will be easy to make, dont worry about the return, i will cut it back, join it and put new pipe in thats fine, i should of looked first!.
PM me your price and Email.
Thanks!
Thanks!
I might be wrong but I thought the lower wings were usually spot welded? With regards, Matthew T.im sure the lower wing clip are simply a U clip squeezed together because the area the wing meets is raised to meet the bottom... and the clip is simply pushed on to hold them.
Nope, row of bolts along the bonnet shut, two in the door jamb, one in the lower rear of the wheel arch, a clip on the Cill and a weak spot weld on the tab to the outrigger that is sandwiched by the bumper mounting bolts at the front of the wheel arch, thats probably the one your thinking of Matthew.
Yes I do recall the spot weld against the bumper mounting Dean, although most of my car wings have been off before and therefore do not now have either the weld or the original lower wing fixing! If you can drill a small hole in the front jacking point a screw should suffice to hold the wing in that location. With regards, Matthew T.
