XM parts mk 1
XM parts mk 1
Who was it that wanted the heating control board, i have now removed it from consul.
Many other parts still still available
Re: XM parts mk 1
Hi, do you have the central locking mechanism for the drivers side rear and front doors?
Thanks
Thanks
Narinder Rall
Leeds
1991 XM 2.1TD SED Silver (Can't let go, won't let go)
2000 Xantia 2.0 HDI Forte Burgendy (Cheap n reliable)
Leeds
Re: XM parts mk 1
I do, I will pull it all out for you, but check if you can to see if its door locking servo unit or the black control box under steering wheel
Re: XM parts mk 1
A 1991 car uses the black box under the drivers dash area.
Re: XM parts mk 1
Dieselman is there a box that controls the ignition under the dash board
Re: XM parts mk 1
Only the ignition switch.southerner wrote:Dieselman is there a box that controls the ignition under the dash board
Re: XM parts mk 1
Hi Apologies for the delay. I will be working on the doors this weekend to grease up the window guides as they are slowing up. Will have a look and maybe send some pics so we are talking about the same thing. The current issues are: rear drivers side door doesnt not respond at all on central locking. The drivers door locks all the doors when the key is turned but none of the other doors respond when I try to unlock. The drivers door unlocks obviously but no signal seems to go out to any of the other doors. Could be electrical problem, dismantling may nudge it all into working but I'll see.....
Ta
Ta
Narinder Rall
Leeds
Leeds
Re: XM parts mk 1
ok let us know as soon as you know
Re: XM parts mk 1
Hi, been ill for a few days. Im selling the XM now but still need to get it in top shape for the next buyer. Will be back on it this weekend so will give you a shout when its stripped.
Thanks
Thanks
Narinder Rall
Leeds
Leeds
Re: XM parts mk 1
How you feeling Narinder, did you manage to find out what parts was needed
