My little wish list
My little wish list
Post by xantia_v6 » Thu Jul 10, 2014 4:04 pm
I am trying to keep my car in pristine condition, and there are a few small parts that I would like to get hold of, or spares for the future.
I will put a list here and update this first post as the list shrinks (or grows).
The car is a 1999 24V V6 ES9 LHD Exclusive Manual transmission in Quartz grey.
Bits for inside:
- Plastic hinge pin(s) for the internal rear window.
- Original factory-fit over-mats (grey), particularly front left and rear both sides.
Bits under the bonnet:
- Right hand ES9 V6 engine mount (complete or rubber donut).
- Headlight wiring harness (1997-on RHD or LHD), Scandinavian spec. with daytime running lights would be nice.
- Screen wash level sensor
Exterior bits:
- any of the detachable plastic trim parts painted in Silver Quartz (mirror covers, scuttle end pieces bumpers etc) in near perfect condition.
- at least one door rubbing strip with a piece of perfect trim to cut down to repair the trim on a front wing.
- a rubber seal for the hatchback tailgate in good condition.
Any other ES9-specific parts that might come in handy one day...
PM me if you have any of the above to spare.
Re: My little wish list
Post by Vince » Fri Jul 11, 2014 7:07 pm
I like your thinking......hope you find what your after :)
Post by xantia_v6 » Sun Sep 14, 2014 3:35 pm
Adding to the list a fuel sender fixing ring (I presume that XM and Xantia are all the same). I managed to break mine today. I will be at the event next Sunday, if someone could look one out.
Post by citroenxm » Sun Sep 14, 2014 5:06 pm
xantia_v6 wrote:Adding to the list a fuel sender fixing ring (I presume that XM and Xantia are all the same). I managed to break mine today. I will be at the event next Sunday, if someone could look one out.
The large Screw Item that holds the Pump/Level sender in place???
xantia_v6 wrote:I am trying to keep my car in pristine condition, and there are a few small parts that I would like to get hold of, or spares for the future.
Bits for inside:
- Plastic hinge pin(s) for the internal rear window. COULD BE PRESUADED TO FIND A COUPLE BUT THEN MY SET MIGHT BE SHORT NEED TO CHECK STOCKS... ;-)
- Screen wash level sensor YES I THINK I HAVE ONE SOMEWHERE
Exterior bits:
- at least one door rubbing strip with a piece of perfect trim to cut down to repair the trim on a front wing. DO YOU WANT A WING TRIM AS IS? CAN DO ONE IN BASE SPEC GREY IF SO? Is it the Crome your after?
- a rubber seal for the hatchback tailgate in good condition. SHOULD HAVE ONE. ILL CHECK TWO THAT I KNOW ARE BUT OTHERS I HAVE NO IDEA
Post by xantia_v6 » Sun Sep 14, 2014 5:18 pm
Yes
xantia_v6 wrote: - Plastic hinge pin(s) for the internal rear window.
citroenxm wrote: COULD BE PRESUADED TO FIND A COUPLE BUT THEN MY SET MIGHT BE SHORT NEED TO CHECK STOCKS... ;-)
I only lost one... It depends how much persua£ion you need
xantia_v6 wrote: - Screen wash level sensor
citroenxm wrote: YES I THINK I HAVE ONE SOMEWHERE
yes just the Chrome, but only need one short piece
xantia_v6 wrote: - a rubber seal for the hatchback tailgate in good condition.
citroenxm wrote: SHOULD HAVE ONE. ILL CHECK TWO THAT I KNOW ARE BUT OTHERS I HAVE NO IDEA
I will be grateful if you can do a few of those parts.
Mike
kingp
Post by kingp » Mon Sep 15, 2014 9:51 pm
Mike you basically want an es9 engine in decent order don't you :)
The engine mount can possibly be redone using the engine mount from the rear of the engine as a base...
Post by xantia_v6 » Tue Sep 16, 2014 9:12 am
kingp wrote:Mike you basically want an es9 engine in decent order don't you :)
A complete engine might be a bit much... :roll:
I think the lower mount is made from a harder compound rubber. so would not have the same performance. It should be possible to get the rubber re-cast to the original specification, but I don't currently know of a suitable supplier (I knew a company that did this, but they went out of business).
kingp
Post by kingp » Tue Sep 16, 2014 11:55 am
With the heat of the engine the top rubber should be fine to be honest and much better than one that's dead or dying :)
Post by Dieselman » Tue Sep 16, 2014 7:30 pm
http://www.elastomer.eu/index.php?lang=lt will do it for you.
Post by xantia_v6 » Tue Sep 16, 2014 8:35 pm
Good spot... They even have a picture of a broken (and rebuilt) ES9 top mount on their web page.
