Off topic chat about anything you like. Doesn't have to be about XMs (though they will inevitibly come up!). You can even discuss
non-Citroens
in here!
Post
by Vince » Mon Jun 30, 2014 10:04 pm
Hi guys,
I cant think of the name of this rough type stuff that is used to smooth over jointwork on the inner wings near the strut tops. I need to replace some as its cracked so ive removed it... its slightly flexible when removed...almost like perhaps half hardened chewing gum....or dried blue tac....any ideas?
Post
by Vince » Mon Jun 30, 2014 10:20 pm
Seam sealer or PU adhesive/sealer seems to be the only stuff I can find...If that's universally agreed with then I reckon I could find something to try to recreate the mottled look finish?
jonathan_dyane
Post
by jonathan_dyane » Mon Jun 30, 2014 10:21 pm
seam sealer? Or do you mean Schultz?
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
Post
by Vince » Mon Jun 30, 2014 10:48 pm
Not sure Johnathan really....I thought shutz was just for stone guarding sills etc?
Ive got some seam sealer stuff here at home, so once ive cleaned up the area and applied some Kurust, I reckon ill give it a go and see how it looks...I'll go steady so I get a good finish.
Now what to use to get a good textured finish?.....I think a sponge or rag applied when its almost dry should do it. See how I get on
citronut
Post
by citronut » Tue Jul 01, 2014 5:41 pm
i think shutz is basically a fast setting underseal,
the stuff in your picy is more the stone guard,
to get that texture it needs to start of pretty thick and sprayed on
regards malcolm
Post
by Dieselman » Tue Jul 01, 2014 6:18 pm
A rag in a poly bag might give an appropriate finish.
