hello,
I need Citroen XM broken 20mm born strut top(since 1995 2.0 turbo or 3.0 V6 or 2.5D)...
give me message please...
Eric Chen
broken strut top wants...
Re: broken strut top wants...
John (XM Exclusive) could be the man to assist you Eric and hopefully he will be along soon! Regards, Matthew T.
Hello Eric
There are 4 different designs of strut top plus Left hand and Right hand.
There are 2 different types of strut rod.
There are 2 sizes of hydraulic pipe thread.
I have to know more about your car and what you actually want to be able to help.
icrc
hi~John...
my XM is 97' 2.0 Turbo with hydractive and 20mm strut bore(bigger strut rod)...
I want to find a pair or one side at least to renovate by elastomer...
in my country, there're too few XM with bigger strut rod and hyractive...
thank you very much!
Eric Chen
Eric Chen
Hello Eric
I see that you are in Tiwan.
I would wish to be sure we have identified the correct parts.
It would be unfortunate to send you parts that turn out wrong.
Can you please make two more checks for me.
Pull down the gaiter and measure the diameter of the parallel part of the strut rod.
While the gaiter is down measure the depth the inner skirt projects from the baseplate.
Skirt depth changed around 1997 and so did the gaiter length to match.
I will then see if I can obtain an extra pair of strut heads to suit your car.
