I just stumbled across this if anyone is in the Exeter area and needs anything:
http://www.ebay.co.uk/itm/CITREON-XM-TU ... 461e4b200f
Regards,
Matthew T.
XM 2.1 series 1 parts
Re: XM 2.1 series 1 parts
This Cranbrook and Hawkhurst salvage are in Kent not Devon.
Think its been there a while if its the same one I collected struts and strut heads from a while ago.
Many thanks for your correction John! With regards, Matthew T.
Altay XM 2.1
- XM newbie
Aracım arada sırada rölanti bozuyor! Yakıt besleme problemi var! Turbo, yakıt pompası ve enjektör tamir bakım kiti ihtiyacım var! Help me! Satın almak için yardım edin!
Google translation (from Turkish)...
"My vehicle occasionally breaks idling! Fuel supply problem! Need turbo, fuel pump and injector repair maintenance kit! Help me! Help to buy!"
(Post also appears in two other threads this afternoon)
Thanks for the translation Chris.
For a 2.1TD we will need to know which year the car is and which fuel system it has fitted. Lucas CAV, Bosch, Lucas Epic.
The turbo's are all the same.
I would suspect the postage to Turkey from the UK for the Turbo will be significant and would expect Serbia or Croatia to be cheaper.
There is a 'Cranbrook' in Devon now, a huge Estate to the east of Exeter, suddenly sprung up several years ago,
doesn't appear at all on my satnav. I use to live not to far from the other one in Kent.
