Buying AC climate temperature sensor
Madis
XM newbie
Post by Madis » Sun May 04, 2014 8:23 pm
Hello, since I can't find any of those on ebay(and there are not that much XM's in Estonia), I'll hope to get lucky here.
I need it for my Y4 XM, the sensor is in the roof(light panel), picture of it can be found: http://www.upload.ee/image/4037424/WP_20140503_008.jpg.
Jan-hendrik
Re: Buying AC climate temperature sensor
Post by Jan-hendrik » Mon May 05, 2014 2:02 am
What's wrong with it? I think there are people on this forum who have cleaned and fixed them.
Madis
XM newbie
Post by Madis » Mon May 05, 2014 8:35 pm
I had problems with it in last summer aswell, the AC started to blow only cold air. Then I cleaned it and everything was fine until now. I cleaned it again but the AC still blows cold air. It has been pretty noisey in last ~1.5 years when it was still working, now after it started causing problems again it's not making any noise. The little rotor still goes around in it but I supect that it's not rotating fast enough.
Jan-hendrik
Post by Jan-hendrik » Tue May 06, 2014 2:07 am
I've never heard of this sensor to fail, which is not to say it's impossible.
Parts of the AC system that are known to fail though are the flap servo motors. I've had this myself three times. If the motor for hot/cold malfunctions the flap may be stuck in the cold mode. I'd start looking there first, before suspecting the roof sensor.
Post by White Exec » Tue May 06, 2014 6:20 am
The roof-mounted tiny sensor motor should operate just about silently. Any noise from it suggests the motor bearings are dry.
Jan-hendrik
Post by Jan-hendrik » Tue May 06, 2014 6:44 am
White Exec wrote:The roof-mounted tiny sensor motor should operate just about silently. Any noise from it suggests the motor bearings are dry.
Yes, and it does not suggest anything wrong with the sensor.
