Wanted: 2.1 TD Lucas injectors
red_dwarfers
Post by red_dwarfers » Tue Apr 29, 2014 6:27 pm
I've been having one or two problems with the injection side of my Peugeot 605 2.1 TD. Basically I need a set of 4 working Lucas CAV injectors as fitted to the early XMs.
I'm not sure whether the ones fitted to the 1.9s or the EPIC can be used in place, Service Citroen reckons they are different part numbers.
'07 C5 2.0 16v HDI VTR estate
'81 GSA 1.3 Club
Re: Wanted: 2.1 TD Lucas injectors
Post by citroenxm » Tue Apr 29, 2014 6:36 pm
Kev
Theres a good working Lucas SETUP on the last 2.1 TD I stripped and another set on the SEd thats now stuck half way through stripping.
What was on that engine you used for your XM rebuild??
Post by Dieselman » Tue Apr 29, 2014 6:59 pm
What problems are you having that isn't curable with the injectors being refurbed?
Post by Peter.N. » Tue Apr 29, 2014 7:29 pm
I have used Lucas injectors with a Bosch pump Kev so I don't see why it wont work in reverse.
Post by citroenxm » Tue Apr 29, 2014 7:31 pm
OPENING PRESSURES thats why...
I think Bosch injectors have a HIGHER opening pressure then the Lucas, so Lucas injectors will open with a Bosch pump, but I dont think they will the other way...
Post by Peter.N. » Tue Apr 29, 2014 8:11 pm
Quite possibly Paul, it was in a BX and it went like a train with the Bosch pump.
Post by CitroJim » Wed Apr 30, 2014 3:27 am
Kev, have you determined the injectors are iffy following the test plan I suggested?
red_dwarfers
Post by red_dwarfers » Wed Apr 30, 2014 6:47 am
The Lucas injectors and pump were from the engine I used for the XM engine rebuild.
I could get the injectors refurbished but it will cost just shy of £250, I'd like to see if I can get known good second hand before I go splashing out.
I did the glass jar test, not a sausage came out of any of them. Thought that it was either the injectors seized or pump not kicking out enough pressure. I took the injectors to Electrodiesel in Exeter for testing and they said they were all seized.
Sent from my GT-I8190N using Tapatalk
'81 GSA 1.3 Club
Post by CitroJim » Wed Apr 30, 2014 7:47 am
Excellent Kev, you know you can dismantle them and see if you can free them off? Got to be worth a punt. Likely only gummy old fuel sticking them..
Do one at a time and carefully note any shims you find. These set the pressure at which the injector opens and sprays.
red_dwarfers
Post by red_dwarfers » Wed Apr 30, 2014 8:17 am
Thats a point. Is there anything to bear in mind when taking them to bits?
'81 GSA 1.3 Club
