Outside temperature sensor
Does anyone have an outside temperature sensor to sell? Even better if you are attending the X Rally tomorrow.
Re: Outside temperature sensor
Post by Peter.N. »
You can apparently get some cheaper ones on the net somewhere although not on ebay it seems. The problem with a used one is that they have a limited life so unless its off a fairly late car it might have the same problem - reading high usually. They are the same as the one used on the C5 and probably most other PSA cars.
There are some new ones currently offered on ebay for £10 by a regular Citroen parts supplier just west of Heathrow.
xmexclusive wrote:There are some new ones currently offered on ebay for £10 by a regular Citroen parts supplier just west of Heathrow.
Do you have a link by any chance? :)
Post by XMX »
Will, Your just lazy !
If you'd typed in the E-bay search field 'Citroen outside air temp sensor' it finds only ONE listed (@ £28.50) from that I deciphered the part #6445F9 then sort into 'Price P+P Lowest first' (But not really necessary as there's only 10 items currently listed) !
Then select the one you wish to look at/or order, simples ;)
I'm sure THIS is the one John is referring to, I'd avoid the CHINESE COPY :lol:
Hi XMX
Got it in one, as always, thank you.
If anyone is lazy it is me for not taking the trouble to add links to my posts.
Post by Peter.N. »
Cor! that is cheap.
Thanks XMX.
