Wanted Series 1 Rear Light Assembly
Motomarky
XM newbie
Post by Motomarky » Sat Apr 12, 2014 11:25 pm
Due to a runaway shopping trolley I need a Series 1 tailight assembly. The left side is damaged, but would prefer a matched pair if anyone has a set. I am in Australia, so these things are really hard to get hold of. Cheers.
Re: Wanted Series 1 Rear Light Assembly
Post by citroenxm » Sun Apr 13, 2014 2:45 pm
The "Coloured" plastic strips are removable, so if these are not damaged on your car they can be swapped onto any rear lamp you can source...
Motomarky
XM newbie
Post by Motomarky » Mon Apr 14, 2014 10:11 pm
Please see attached photo for additional information. As you can see at a pinch I can live with the minor damage, but it would be nice to have an undamaged lens.
lankytim
Post by lankytim » Thu Apr 17, 2014 12:03 pm
Are these the same as series 2? If so I have one.
Post by citroenxm » Thu Apr 17, 2014 1:07 pm
Yes. . They are all the same..
Post by xmexclusive » Thu Apr 17, 2014 1:52 pm
I do not think they are all the same.
The top lens is available in white or smoked.
I asked for the photo to be put up because of the postage cost to Aus if it is wrong.
Post by russ92xmsed » Thu Apr 17, 2014 5:43 pm
To me, the early cars smoked panels started black but then faded to that brown pink colour. The later mk2 cars seem to have a much darker smoke finish, that doesn't seem to fade as much. Could be wrong there though!
Also the red parts can be different. I had a much darker early lens fitted at one point which was a complete contrast to the brighter lenses on the rest of the car. They must have tweaked them for mk1.5 versions. Very late Mk2 seem even brighter in my opinion.
Post by Dieselman » Fri Apr 18, 2014 3:15 pm
IMHO, all the units start out the same, they just age differently. Darker lenses are mainly due to exhaust pollution.
Post by russ92xmsed » Fri Apr 18, 2014 3:46 pm
I expect your probably right Will.
Post by citroenxm » Fri Apr 18, 2014 6:46 pm
russ92xmsed wrote:I expect your probably right Will.
Thats EXACTLEY WHAT I SAID at the Start, they are all the same!!!
