On the road again
steelcityuk
On the road again
Post by steelcityuk » Thu Apr 10, 2014 1:38 pm
Hi All,
The XM is back on the road again and I'm not convinced she's riding like she should. The pump makes this strange rattling sound at idle, well it seems to be coming from the pump. I'd like to build a gauge for checking the output from the pressure regulator, unless this is correct I could be chasing my tail trying to sort out the ride quality. There's a video on youtube of a pressure test, has anyone else see it?
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Re: On the road again
Post by Dieselman » Sat Apr 12, 2014 1:04 pm
steelcityuk
Post by steelcityuk » Mon Apr 14, 2014 12:44 pm
Yes DM, that's the one, the AFTER video seems to show a slower rate of pressure loss too.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Post by Dieselman » Mon Apr 14, 2014 7:42 pm
The relief screw wasn't open as much.
steelcityuk
Post by steelcityuk » Tue Apr 15, 2014 1:31 pm
Another job that needs tackling is a thermostat change, she's only just getting 'on to' the temp gauge.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Post by Peter.N. » Tue Apr 15, 2014 6:19 pm
That's a bit daunting if you haven't done one before as you cant see it but once you have the bolts undone, not to difficult.
steelcityuk
Post by steelcityuk » Wed Apr 16, 2014 10:10 am
Thanks Peter, I've read a couple of postings by different members and so I'm not too worried. I've got a 1/4" socket set as recommended. The XM is up in the air at the moment because of a LHM leak from the regulator return, the small rubber pipe has failed in such a way that I need to replace it. The only listing on eBay is £15 so I'm going on a virtual search for a cheaper part. I think that either the pump and/or the FDV is/are playing up too so it maybe time to replace these if I can find the parts.
I hope you're keeping well?
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
