Info help needed on ABS sensors
southerner
ABS sensors for a mk 1 bendix system on a K reg, are no longer made and most supplys have run dry, any one know if there is an alternative wheel senors to replace all four on car
sdelasal
Re: Info help needed on ABS sensors
One option must be to remove the abs completely - it was an option on early cars. Long term, that must be a reality.
Quite a LOT of involvment there Steve, theres quite a bit of pipe re routing as the ABS Block sits on the nearside front, where on a non ABS car the pipe work doesnt come that way.
Yes it does.
Irrespective, just remove the unit and splice in some pipes.
Ah that's a good thought actually... its late .. and I'm fed up.. not thinking straight.
southerner
would any of the mk2 wheel sensors fit and work
Yes, Teves sensors use the same mounting arrangements.
I was comparing some XM Bendix and Teves rear sensors last weekend.
Was not happy that the Teves sensor would get close enough to the ABS ring to work the Bendix ECU.
Need to try it in an actual car that needs just a sensor.
southerner
give me more details and i will give a try
I tried that, on an open wheel bracket (cut) That seems to fit fine.
southerner
What i think I would need to know is the part numbers, Euro car parts are selling sensors with the blue plug that they say will work
