Damn. Head gasket gone
SamWise
My indy quoted me £7-800 to do it (not hoping to get the work - he told me it was time for a new car). I guess that my XM experience is over! Assuming it's going to be scrapped (unless someone here has a use), one of you may want the leather interior, which is in good nick.
SamWise
Re: Damn. Head gasket gone
Actually, looking at the Haynes, maybe I should attempt it? Who's done the job on the 2.1TD? Is it suitable for an inexperienced mechanic?
kenhall
Over to you Peter!
Ken
Ken
Over to you Peter!
robertmnorton
Hi Samwise,most of us 2.1 owners have done one or two(or more).The job is really down to nuts&bolts.Yes,access to some of these will skin your hands and have you swearing,but is do-able insitu.The timing covers and crankbolt can be a pain.I found by disconnecting the lower engine mount and rotating the engine forward slightly,(i used 2 trolley jacks to support engine & g/box)you could install a 4"x4" wooden block between bulkhead and block to allow the head to be easily lifted and replaced, no need to seperate cam carrier.The most awkward bit is getting the inlet/ exhaust manifold bolts (nuts) off or on.Preparation is everything,tools,parts and a constant brew.Both mine i did over a 3 day stint,it is physically demanding due to the body contortions needed,so plan it and take your time,double,triple check everything and don't throw removed bolts into a single jar!It may sound daunting but it REALLY is just nuts&bolts.THERE WILL BE ADVICE A' PLENTY ON THIS SUBJECT,many of the guys here will recount their woes,all sound advice.
robertm
robertm
SamWise
I think I'll give it a go. Frankly, the other option is scrapping it, so it's worth chancing the £20 for a gasket (and I'd be an idjut not to do the cam belt at the same time) and giving it a go. Looks like my Sunday is all set! I had a BX snap a timing belt once, and managed to replace the head with one off a scrapper and even got it running, though it spat all the coolant out and I gave up in the end (had already bought a replacement). If I can do that, surely I can do this. There's been no overheating or anything like that, so I can't see any reason why the head would be warped.
DerekW
Hi Sam,
I don't know where Peter is, he must be asleep!
Guaranteed he'll be along in a minute.
As Robert wrote, it's only nuts and bolts.
Please don't even think about scrapping your car.
Derek
Derek
SamWise
It's definitely do-able in situ is it? I don't have any chance of pulling the engine, let me tell you.
robertmnorton
Hi again Sam, yes, i did both mine in-situ.A 92 s1 SED, and a 95 s2 exclusive, both with A/C but you don't have any need to mess with this.
robertm
robertm
demag
Don't forget to change the water pump as well! Nothing worse than seeing that tell tale dribble when you've just got it all back together!
2.5td......Now sold.
BX1.6TXS
Fiat Multipla 115Elx Jtd (Not quite standard!)
Dave.
BX1.6TXS
Dave.
