wtd: radiator drain plug for 2.0l
sdelasal
Post by sdelasal »
In spite of being careful i managed to snap the rad drain plug in two. I found a m12x1.75 bolt to fit but it took some dressing with a file to get the size the same as the threaded piece that broke off in the rad (and which, luckily, i was able to extract with an easy out). I'd rather have the proper drain plug so let me know please if you have one spare from an old radiator. The plug has about 1/2"length of treaded section which screws into the rad, about 1/2" of a large nut section then about 1" of drain tube. I have a spare 2.1td rad but the drain plug is different.
