hi there!
Bertie-Bassett
hi there!
Hallo xm peeps
i have a xm 2.ol turbo. Advice needed, thanks
citroen xm 1994.
Re: hi there!
What do you need?
Re: hi there!
Fire away! We shall try our best!
Bertie-Bassett
Re: hi there!
Erm.. check engine light on? and abs out light on? I have been failed on mot due to this. thanks
citroen xm 1994.
Re: hi there!
ABS light can be anything from a dodgy connection one one of the four sensor plugs, to a duff sensor completely, to an issue with the ABS block..
Useually a duff sensor. Ive also known it to be as simple as dirt between the Sensor end and the teeth of the ring...
Check light.. Could be a Lamba sensor giving duff readings, to an air leak in the intake system. Idealy the car needs to be put on a Lexia or Elite Diagnostic to read out the fault codes..
Bertie-Bassett
Re: hi there!
Do Citroen main dealership have these systems for checking still?
citroen xm 1994.
Re: hi there!
Absolutely so paul, a Lexia/ELIT check can save hours of faffing around trying this and that in blind hope... A few seconds on the ELIT went straight to Sam's problem the other day on his TCT.citroenxm wrote: Check light.. Could be a Lamba sensor giving duff readings, to an air leak in the intake system. Idealy the car needs to be put on a Lexia or Elite Diagnostic to read out the fault codes..
Bertie, where are you as over on FCF there's a list of Lexia owners willing to run diagnostics and not only will it help nail the engine issue but the ABS problem too..
I'm near Milton Keynes, just off the M1, and always happy to run a diagnostic and offer advice following same.
Re: hi there!
Yes, but its about 150 a go!
Theres a fair few people dotted around the country who have them and some are willing to pop them on members cars to do a session...
If you havent already, it may be an idea to put your location up, so we have an idea where you are
Re: hi there!
They do but their knowledge of the older stuff may well be a bit thin on the ground these days and they may not fully understand what the diagnostics is telling them; the Lexia and ELIT are not very verbose at times and their findings need some degree of interpretation and often only make sense when you really understand what you're diagnosing; they don't give an answer on a plate.Bertie-Bassett wrote:Do Citroen main dealership have these systems for checking still?
I doubt many current service technicians know much about 90s Citroen engines and ABS systems. We do!
They also charge a lot too...
Re: hi there!
Sorry Paul, you and I have been typing at the same time and saying much the same... Not deliberate sir, by any means...
