Wanted: kickdown cable for 2.1TD
sdelasal
Post by sdelasal »
I just discovered that the kickdown cable is badly frayed in a couple of places. The obvious one is where it runs around the wheel on top of the injection pump & I had planned to simply splice a new piece of cable in for that. However, I've just discovered another frayed area just inside the cable outer-cover where it attaches to the pump. So I need either a new or good used cable or a replacement inner cable. Anyone got some thing suitable or know how best to repair? Steve
Re: Wanted: kickdown cable for 2.1TD
Post by robert_e_smart »
I might be able to help you out. I shall have a look for you.
Ohh does your car have a Bosch pump?
Arent all Autos either Bosch or Lucas Epic Robert? and the EPIC wont have a kick down cable wropped around a pully.. ;) So, Id say YES it is a bosch fuel system..
The Lucas Epic does have an elaborate pulley system, too. I'm just worried the cables are different lengths.
Yea I wasn't certain Robert... but the give away was the "wrap around a pully ON TOP of the PUMP" ;)
Gonna have to get used to the "EPIC" engine bay, my Mates friend has bought an R reg estate with Epic auto in it.... Oooerrrrrr..... :P
Ahhhhhhh ha! Thanks Paul.
Just for info, service Citroen has differnet kickdown cable lengths for each engine option.
I SOOOO want one of those Thermostat houses to put on an early 2.1 TD instead of the awfull canister setup...
Have you one spare Robert.. (I know, I know, its NOT theroetically a thermostat house, thats round the back)
Are you at CXM Robert?? Im there fri, sat and sun... YIPPEEE
Post by CitroJim »
citroenxm wrote:I SOOOO want one of those lovely EPIC pumps on my 2.1 TD instead of the awfull Bosch setup...
Corrected an error in your earlier post Paul ;)
How did you do that? Have you been granted powers now on here Jim??
Post by CitroJim »
citroenxm wrote:How did you do that? Have you been granted powers now on here Jim??
No... Just edited the quote...
