Hi,
After a long time searching I have finally found an electric armrest mechanism, box and rubber gasket / seal here in New Zealand, now all I need is the switch and plug! Hopefully someone has a spare one they are willing to sell (no idea if they are rare or not??)
I will also need a couple of the switch blanks to finish it off.
Thanks,
Jordan.
Electric armrest switch
1992 V6 12v Auto RP5176
Re: Electric armrest switch
you may havea long search, the switch itself is the same as the rear window switches that are mounted in the centre console but to get the one with the right decals in will be almost impossible, german or french ebay will probably be the most fruitfull hunting ground. dont forget if someone has the blue body armrest switch but its broken you can swap the buttons onto a rear window switch.
Hi Jordan
I will add the switch and plug to the ignition switch wiring I am supposed to be finding for you.
Should have them, just not found time to look anything out.
That wasnt really as difficult as i made it out to be was it
hi jordan
I think I have found one too if john does not have one.
thanks
remy
thanks
remy
Not really...Dean wrote:That wasnt really as difficult as i made it out to be was it![]()
