newbi
stan
newbi
hello all
ive just got my 2nd XM . i used to own a j reg xm prestige saloon 2ltr 10 years ago, ive owned many other cars in the ten years but none as good so ive now purched my second xm , its a 3ltr 12 valve n reg exclusive in black with only 52k on the clock, the only fault so far is the AC doesnt work . it hasnt been recharged for some time so i think all the rubber gaskets will have perished but i am well cuffed with the car and i am planning to use it every day
Re: newbi
Eddie, dont worry, the project one I have will have a 62k relacment engine AND box in it when I restore it..
Welcome Stan!
Welcome Stan!
Re: newbi
Welcome Stan and the early S2 with a V6 12v engine is certainly an interesting combination! Regards, Matthew T.
Re: newbi
These Early S2 PRV V6 engines are a different CC to ours, and the dip stick is also relocated to the centre of the front heads, rather then comming up to the left side..
I couldn't tell you the exact CC decrease or increase now..
Re: newbi
I did not realize there were those differences Paul and I will look closer next time I see one!! Regards, Matthew T.These Early S2 PRV V6 engines are a different CC to ours, and the dip stick is also relocated to the centre of the front heads, rather then coming up to the left side..
Re: newbi
MTXM wrote:I did not realize there were those differences Paul and I will look closer next time I see one!! Regards, Matthew T.These Early S2 PRV V6 engines are a different CC to ours, and the dip stick is also relocated to the centre of the front heads, rather then coming up to the left side..
Ive got one of these later "Last" engines to go in my K reg SEi when I get to restore her!
Re: newbi
Hope you do not find the "missing" 12 cc's spoils your enjoyment once you have the later engine in.
Re: newbi
Possibly not John, as running the older unit on LPG had it running down on bhp anyway..
