Looking for si front grill (GREY )for the xm. think my abs ecu is duff too.
thanks T.
Wanted..s1 front grill. And abs ecu.
- spitroen
Tony.
S1 Auto prestige 2.0 turbo petrol. RP 6064. Production date. 19/06/93.
Saab 9-5 HOT 2.3 Aero.
Re: Wanted..s1 front grill. And abs ecu.
Tony, what makes you think the ABS ECU has thrown in the towel? They're pretty reliable old things and rarely fail. More likely the valve block or safety relay has gone into a sulk......
What's the colour code for the XM, Tony?
Might be able to sort you a front nosecone out for a Series 1 XM. Funnily enough it came off of a Prestige, too...!
Postage might be interesting, though...
Ive also a PILE of S1 nose cones...
But not ABS stuff though...
I'm sure the postman will be absolutely fascinated...Duke wrote: Postage might be interesting, though...
The S1 Nosecone that was removed was paintcode ENT, not sure if that's the same as your Prestige, Tony.
- spitroen
Hi duke. The paint code is 2T37
Tony.
- spitroen
Is that not the paint code. I found this on inside front near headlight. ??
Tony.
Paint code is useually under the grime, DIRECTLY behind the passenger headlight, forward of the Air cleaner on the chassis member...
- spitroen
Found it. ETW. Thanks.
Tony.
