WANTED: for the 2.1 sd interior trim
Wanted for the sd.. two bits of plastic trim on the inside passenger side..
The bits are the black plastic that runs along the edge of the carpet.. the two pieces are the plastic bit at the front that curves up towards the fuse box cover.. the other one is at the back that goes up the C pillar and holds the rear carpet down..it starts at the side of the rear seat base.. the middle section is fine ive got one of those..
If no one is sure ill get some pics tomorrow..
Re: WANTED: for the 2.1 sd interior trim
Post by MTXM »
I am sure they can be reclaimed from the Mandarin car Paul, assuming we go ahead as planned! Regards, Matthew T.
