v reg 2000 xm 2.1 td estate
savoy
Post by savoy »
Hello
any good to anyone !!!!!!!!!
silver v reg 2.1 td automatic estate [we have sold many times] now showing 215k.Good auto box.
Been with us and looked after since 90k.
Back in stock again.
BAD NEWS
requires and engine,[alloy sump cracked and head problem].
REQUIRES AN ENGINE
Car still too good to scrap.£400 as is or looking for a full engine assembly.Old or late unit [as long as it can be heard running.
If you wish for the whole car will need trailing away.
Motd till may taxed till april 2013.[just 12 days left]
Call me on 07831 898573 or 01282 773466 for further information
Re: v reg 2000 xm 2.1 td estate
Post by CitroJim »
What's wrong with the current engine then Malcolm?
I believe the head is cracked and the loss of oil from the sump damage is not worth the risk of bottom end potential knock if its been starved..
savoy
Post by savoy »
Hello to you all
just to clarify the fault,bottom a/c pump bolt hangers are cracked and leaking oil quiet quickly.
Fastened a s/h head 6000 miles ago,but now has pressure in the coolant system again.[S/h head had been welded before so not the best head to use.
NEED A FULL ENGINE WITH ALLOY SUMP TO CURE.
IS IT WORTH DOING ????
BODY STILL GOOD SLIGHT PAINT BUBBLES AROUND REAR WHEEL ARCH SECTIONS.
can anyone help.
would buy a full car cheap if there is one about.
Regards to you all savoy.
3 ltr w reg silver update
engine and box back out,box stripped and pump swapped,2 new bush,s and a bearing fit .
LET US PRAY.
Should be back together next week.Will try and get it to the next citroen meeting
I've got a complete 2.1TD engine with alloy sump and was coupled to an auto transmission.
It came out of a running car with 160k miles on. I scrapped the car due to underbody rust.
PM me if interested.
savoy
Post by savoy »
Hello
what sort of cost is the engine please to us.
Regards Malcolm
07831 898573
Post by CitroJim »
savoy wrote: 3 ltr w reg silver update
LET US PRAY.
Excellent news Malcolm :D I'm sure the 'box will be good after this. Did you find anything definite and what bearings did you replace?
savoy
Post by savoy »
hi Jim
many thanks fo r your information ref box internals.
Sent the box back to Colin at west coast transmitions of Blackpool,[trusted him for the last 20 years].
Don,t trust many people beside,s me and you.
Believe
2 metal bushs replaced
oil pump from old box used
i think the taper roller bearings been changed as you advised,
Its all built back up again when collected.Re,con torque converter was sent back and tested again.
Will keep you posted.
Regards to you and once again thanks for your help.
Malcolm
savoygarage.co.uk
