headlight washers
vive la difference
headlight washers
Post by vive la difference »
Hi Everybody
The XM passed its MOT this morning (no problems)I am pleased to say, So i will now re-register it on to UK plates
I am wondering does anyone have the plastic cover for the headlight washer jets? RHS
Regards Brian
citroen xm S1 v6
Range Rover P38 4.6 HSE
Alfa Romeo 147
Re: headlight washers
Post by MTXM »
Hi Brian,
Well done with the MOT and just to let you know that Dave (the rave) has made a mould and can provide excellent quality replacement washer jet covers.
Regards,
Matthew T.
vive la difference
Hi Mathew
Many thanks for that information , I will follow that up with pleasure
Following the MOT , I have stripped out the defective speedo cable, (top section broken adjacent to the speedo head, Any ideas the best place to find a replacement
Thanks again Brian
citroen xm S1 v6
Alfa Romeo 147
vive la difference
Hi Mathew
May i ask how do i contact Dave
Regards brian
citroen xm S1 v6
Alfa Romeo 147
Currently a pair of speedo cables on ebay.
Will list the numbers just in case they are the right ones.
Send PM to davetherave who you can find on the members list.
I noticed this John yesterday. I tried to check the parts numbers for the cables aswell...but the only ones I found didn't match with the the listing parts number. To me they don't look long enough...but having never seen one out of the car, I couldn't possibly comment!
I hope they are.....
Post by XMX »
vive la difference wrote:Hi Matthew
May I ask how do i contact Dave
Regards brian
Here you go fellow !
Click on the Photo for link to thread ;)
Post by Duke »
Great news Brian re the MOT! :D
vive la difference wrote:I have stripped out the defective speedo cable, (top section broken adjacent to the speedo head, Any ideas the best place to find a replacement
Do you mean just the nylon clip is broken, if so just repair it by plastic welding, filling with a nylon from a ty-wrap, and adding wire as a support.
I put a collar of wire round both parts and tensioned bits between the collars....if that makes sense.
vive la difference
Hi Everybody
Thanks dieselman, The problem is that the inner has broken(at the point that it enters the speedo, and the fixing collar! has broken as well!!
Any advice as to how i remove that part of the dashboard that houses the clock/information panel,It seems to be cliped?? at the top edge
Many thanks Brian
citroen xm S1 v6
Alfa Romeo 147
