Series one register update
I attach a slightly revised register and forgive me if I have not included all earlier adjustments notified. Please do let me know whether any other changes and/or additions are required. Regards, Matthew T.
Re: Series one register update
Matthew, point of order sir...
Does the register include the S1.5 such as mine or is this strictly for S1 only?
Matthew, Can you add mine to the 1992 block please. Thanks..... 2.1 SED of course!
Well Jim, if Matthew has made the register up to 1994....then you should be added. It's still a mk1.
Many thanks Russ and Jim and I am sorry not to have added your cars before!! There is a column for the later Prestige model Jim and you are the only one at present! Best regards, Matthew T.
Thanks Matthew
Thanks very much Matthew.
Now there is another mk1 XM which I can tell you about if you want to add it. It is an SD, and it is the sister car to mine. I don't know the owner ( but spoken to him at CXM) and I don't know if he is on here or a member of the CCC, but his was registered within in a week of mine. Same number plate too...K8**EJD. So could add his as ?EJD!
All the best
All the best
