The first racks pinion was overtightened to the point i could not move the rack within the housing, oh well i will just take it back, after all these things happen sometimes.
Rack 2 was a real piss take everytime it was moved to full right lock the N/S gaitor would pop off and the N/S rack support bush was goosed, so back that went.
Rack 3 involved a 4 week wait, they said they didnt have any other racks in stock, i was calm because i wasnt planning on doing the job for ages so dispite being irritated i kept quiet, unfortunatly when it did eventually turn up it was the same worn out peice of c**p i had sent back 4 weeks earlyer with a different gaitor on the N/S held on with two tiny little zip ties
By now im pissed off good and proper, they promise rack 4 would be with them in two days, and it was........all well packaged in a box, the gaitors were held on right and they werent really cheep pants ones, now there was i tiny, tiny bit of play in the N/S bush but barely any movement really so i rolled with it and took it home and put it on the shelf in the garage to await the day when work would commence.
Today was that day and i picked out a good ram and cleaned up and painted everything to fit onto the recon rack but as i was about to assemble everything ready for it to go in tomorrow when i get the old rack out of my car i suddenly realised what those morons who re con these racks had done, can you see?.....
Well, the pinion valve is on back to front, which in itself has annoyed me again, but the threaded hole the 6mm bolt that holds the main feed and return pipes (red) on by their bracket has i sheared off bolt in it...................steel sheared bolt, in the alloy housing, i really hope i have calmed by tomorrow because if i go back into SCS in the morning and that little git on the counter trys to tell me nothing is wrong with the rack AGAIN im affraid i may insert it in him
