Wanted two exhaust manifold studs
zaphod
As above, I need 2 for my TCT turbo, one was already missing when I took it apart, the other is partially sheared!
1992 Range Rover Vogue SE
1985 Golf GTI
1975 MG Midget
1959 Austin Healey Sprite Mk1
1985 Golf GTI
1975 MG Midget
Re: Wanted two exhaust manifold studs
Damm Stuart .. should of chucked a few in.. the ones i removed are probably lieing on the floor.. ill be at the farm again Friday.. ill have a look and chuck a couple in a jiff bag for you.. unless your appearing at cxm on Sunday which case i can bring and had them to you...
zaphod
That would be really good, I should have ordered them when I ordered the rest of the bits from the local main stealer but forgot about them. Unfortunately I shall be putting TCT together at the weekend! the missing studs won't really be a show stopper till I want to put the heat shield back on
1985 Golf GTI
1975 MG Midget
1985 Golf GTI
1975 MG Midget
Most fixings and fastenings suppliers, or motor factors will stock studs.
zaphod
problem is round here none are open at the weekend!
1985 Golf GTI
1975 MG Midget
1985 Golf GTI
1975 MG Midget
