,jelly mould , alloy wheel centre disc etc.
topcat1936
NEW TO THIS> can any one help me locate a centre disc for the jelly mould type ally wheel. also a front wing. and rearhatch EXCLUSIVE badges. thanks in anticipation.
Re: ,jelly mould , alloy wheel centre disc etc.
S2 Exclusive cars only had Citroen on the Left and Italic XM on the right... Is it these you need?
I can possibly supply a wing, but it wont be the correct colour, and would need painting...
The centre caps are common to Peugeot alloys of the same eira too.. The "Feet" break off quite easilly.
I've got that feeling...citroenxm wrote: The "Feet" break off quite easilly.
topcat1936
thank you for taking an interest is that feeling you have a possibility that you may have a little disc that i am looking for.
topcat1936
thanks again for your response and info, i had not seen all your mail before my last reply. the xm is in the workshop at the moment, as i am changing the engine etc etc. so there is no haste.. i will keep looking in the meantime and something may turn up with the sump i am also looking for. regards.
Alas, no, I don't have any disks.topcat1936 wrote:thank you for taking an interest is that feeling you have a possibility that you may have a little disc that i am looking for.
topcat1936
hello citroenxm, thanks for your reply. just to clarify, i am looking for two self adhesive EXCLUSIVE badges as fitted to ser2 xm front wings, and also fitted to O/side lower edge of the rear hatch, just as fitted to my previous and present xm. also do you know which peugeot models are fitted with the centre discs as previously discussed. i hope i am putting this in the right box, as i have not done this before. many thanks TC.
I have moved to the more appropriate sales and wants section rather then at scrappers section...
topcat1936
hi citroenxm man , thank you for your redirection instruction to me, i am learning rather slowly. i have had a look at the sales section and cannot find any message back to me from you. will you be sending a message/reply or could it be elsewhere. please forgive me labouring this as i am trying to get familiar with the modus operandi of all this.kind regards TC.
Don't panic... the topic will just carry on as before just the main heading is sales and wants instead of seen at the scrappers...
