Wanted - auto bake pedal switch
Post by andmcit »
OK, this is for a Xantia but I'm pretty certain it's the same on the Xm auto!
The switch has had it as there's no red glow at the back end and LEXIA just
confirmed it!
Item "2" BVA is the bit I'm after although illustration shows narrow manual pedal width:
The pedal rubber is fine and I can use the one I've got so just need the actual switch:
I've followed up x3 cars now that were being broken and have been told
each time that it was left on the shell and weighed in!! Row locks...
There must be sone autos out there being broken as they're always far more
prevalent than manual box cars?
Re: Wanted - auto bake pedal switch
Hi Andrew
I though that the actual switch body was the same for all XM's.
Just the pedal body and rubber wider on the auto.
There are two versions of the switch but that concerns number of wires and contacts (2 normal, 3 for cruise).
