Wtd: XM radiator hose
ds21
Hi, just wondered if anyone has a bottom radiator hose for a 94/95 XM 2.0i Turbo they wish to part with?
Cheers
Cheers
Re: Wtd: XM radiator hose
is it an auto? if so i might well have.
ds21
Hi, yes its a 2.0 Auto without A/c.
Cheers
Cheers
I shall write it on my hand now so i dont forget and have a root about in the spares stash in the morning for you, 98% sure i have at least one good one.
I brought it home today, i will get a picture later, it has the T section and pipe that runs to the Gearbox oil cooler, think its the beasty.
ds21
Hi, still looking for the hose, it runs from the bottom of the radiator to the rear of the engine with 2x smaller pipes T-ing off - one to the header tank and one to the engine oil cooler.
Cheers
Cheers
I have a set of Xantia TCT hoses, but they are probably different.
sorry, took pictures last night then forgot but mine runs from the waterpump housing on the back of the block to the rad with one smaller pipe 'T' off which runs to the transmission oil cooler.
- ludi
- XM newbie
First sorry for hijack,
Second,and more important to me, are radiator for 2.1TD D12 and 3.0 V6 the same, is it possible to put a rad on my TD from a v6?
Thanks
Thanks
Hi Ludi,
Nope they are NOT the same, The TD top hose attaches on the LEFT side, the V6 on the right...
I have a couple of spare 2,1 TD rads in the shed.. Are you in the UK?
