Wanted: S1 Speedo Upper Cable
- citroenmad
Im after a speedo cable for a S1, the upper section. Mine has snapped at some point along the cable and the end which connects to the speedo has also broken off. Citroen no longer supply them and I can't seem to source one from elsewhere. If anyone has a good one they would want to sell that would be much appreciated.
I think there will be the posibility of getting one made, however I would much rather have one ready to fit in.
Thanks,
Thanks,
Re: Wanted: S1 Speedo Upper Cable
To get one made try Speedy Cables.
- citroenmad
- andmcit
Cannot make promises about how quick I can get hold of one but I guess there'd
be one available sometime with my spare cars although it's a bit long winded getting
these out. Best suggestion if you plan on removing yours current duff one for a pattern
is tie a length of string to one end and draw it out leaving the string to draw the new
one back through. I'm pretty sure it helps being drawn through from the instrument
cluster through under the glovebox and out. I recall a right git of a circular rubber
grommet on the bulkhead that IIRC get's pulled out into the engine bay.
I honestly may not get the time to spare taking things apart though. Have you tried
ebay Germany, Holland, France etc?
- citroenmad
If you could drag one out for me that would be ideal Andrew, just let me know if you manage it
Ive not, but wont the speedo cable from a LHD car be different?
- andmcit
Silly me - of course Chris! I was thinking about the lower cable section for a moment! lol
As Andy says, draw the cable through with string tied and tye-wrapped to the cable sheath.
Pull the cable into the engine bay, it pulls through easily.
- citroenmad
- andmcit
Rightho - I have a cable but TBH it does look a bit short!! I wouldn't even be surprised
if it's a LHD one I kept off a v6 I scrapped a while back so it'd be handy to know the
length of a RHD one if that's possible!! lol
- citroenmad
I wouldn't like to guess the length and have not got mine off yet, however it must be ober a metre long ...
If you have another one from one of your soon to be culled cars that would be awesome, beer tokens will be sent your way
