Wanted - AC pipes and door
- steelcityuk
Hi Folks,
I'm after a set of AC pipes for a series 1 and also if possible a mandarin red front left door.
Thanks.
Steve.
Thanks.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Re: Wanted - AC pipes and door
Haddnt Dieselman just broke a Manderin Car??
Do you want R12 system pipe work Steve? And for what? A 2.1 Diesel?? Ive just removed an r12 setup from my H reg SED and fitted R134a.. I could route that out for you..
Are you attending X Rally??
Yes but most of the doors added critical mass on the weighbridge...citroenxm wrote:Haddnt Dieselman just broke a Manderin Car??
I have a red n/s front door but its from a Mk2 and don't know about the colour, its metalic.
- steelcityuk
Hi Paul,
The R12 pipework from the SED would be great, let me know what you want for it. I'm hoping to make it to the CXM.
Shame that I missed out on the car DM broke, oh well.
Thanks Peter, I don't know if S2 doors fit S1 cars but if it needed respraying I maybe better off trying to sort out the existing door. I've never been any good at spraying and wanted to avoid it if possible.
Thanks all.
Steve.
Thanks all.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
The door will fit Steve,
Colour match may be an issue though. I have a set of mandarin doors here. It has been so long since I have seen them that I don't know what their condition is. Postage would be dear though.
Peter.N. wrote:I have a red n/s front door but its from a Mk2 and don't know about the colour, its metalic.
Robert, that is correct provided you use the S2 door lock/mechanism (that hopefully will be with it) as most S1's without the additional side impact bar fitted inside the door carcase and therefore it will not possible to transfer the Mk1 lock mechanism due to not having the scallop feature which allows clearance for the side impact bar (As on some S1.5's and S2's) !robert_e_smart wrote:The door will fit Steve,
- steelcityuk
That's great info XMX.
Robert - please could you have a look at the door when you have time and let me know if it's worth shipping?
Thanks.
Steve.
Thanks.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
No problem Steve.
One of the silver estates in the photo should move back home in the next week or so.
No reason why I should not bring the red door on as the car will be virtually empty.
I could then bring it up with a load of bits (part FCF couriers) to Shropshire a little while later.
Part way at least.
Part way at least.
