After posting in the electrics issue to say that I'd resolved the issue with my indicator malfunction by replacing a relay on the Bitron box my happiness was short lived as I've found that in the last 12 months whilst waiting to source a replacement relay I've managed to loose the black plastic box that the PCB sits in.
It's located above the passengers feet when you remove the panel with the flap to access the fuse box. It's mounted on the side of the tunnel between the passenger and driver and has a green relay beside it. It's got one brown and one grey plug coming out of the top of it.
I need the black box only (both parts of it) without the board that's inside it. Also if anyone has one can they make a note of how it comes off. If there's any nuts n bolts holding it on I need those as well unfortunately.
Anybody got anything?
Thanks
David.
XM Series 2 Alarm Bitron Box
David Hallworth
'98 Xantia Activa V6
'00 XM V6 Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Tonx
Re: XM Series 2 Alarm Bitron Box
You could have had mine, but Im afraid Ive burnt it !
I wouldn't give much weight to anything Tonx says, he's probably too busy burning!
